Hock Edition
thank you for the email
			Skid,
The dealer installed the lift and mentioned that the sway bar end links in the front were too short and he didn't want the sway bar flipping under and getting stuck. So he swapped the fronts with the rears and that solved the problem!
Anyone have winch info...?
Will the Zeon Winch fit in an EVO 1/4 Pounder? I've looked at these same options and can't come up with a definitive answer...
Thanks Greg. What's your input on which winch I should get? VR10000 or Zeon 10k. Keep in mind I will only be using it about 10-15 days a year (especially hope to use it at JKX this year!). Is it worth paying the extra ~$350 for the Zeon for that little use? I'm really torn because I like to put nice stuff on my rig, but with a cage, cb, and other optional stuff to buy before this summer, I'm wondering if I really need the Zeon... Any winch advice from you would be greatly appreciated, even of its not one of these two models.
Honestly, since both choices are a Warn you aren't going to go wrong, but since you are looking at other mods too I would just save the extra coin and go with the less expensive one of the two. I like nice stuff too, but either winch is still going to be one of the best currently out there and you can't even see them when they are installed between the frame rails :thumb:
Sounds good. Do you know the difference between the two? The specs on the Warn site aren't really different... Load capacity and gearing are the same, but they don't list the line speed. Is that going to be a major issue? Also, I read the entry level VR series are made in china... Know anything about that?
Eddie? Chris? Winch advice?
I use the 9.5ti warn and have had no issues with it. I would not get the expensive winch unless it was the power plant
Agreed.
You can't go wrong with Warn. I have the Warn cti-s. If you don't have onboard air already, I'd just go with the power plant and be done with it.
So, I can get the Zeon 10k for $900 and the ARB compressor for $250, or spend $1600 on the PowerPlant? That doesn't seem like a good investment...
