Yeah, that's the likely next step.
Seems like that'd pretty much be your only option left. Hope it doesn't have to come to that.
Ummm, yeah, fuck that ^^
You have great patience! Hopefully this is the fix! I had a similar problem years ago that turned out to be an air bubble in the rear of the block and heads. Could not get the engine temp down. Ended up putting bleeder valves in the rear head freeze out plugs to bleed the air out. This became evident when I measured the amount of fluid I was getting out on drain down compared to factory spec.
Keeping my fingers crossed for you!
Agree! F that! Hope that bill isn’t a waste of $.
Interesting, for sure.
I hope that does it! Looking forward to that “all is good” post!
We all could do what is pictured, the trick is putting it all back together. Good luck Doug
I could see a warped head but enough to cause a problem ‘should’ have given you more indication. Hopefully it is and you’re back to normal.
My son blew the head gasket in his little race car and this is the pic he sent me so you may be all fixed I hope
Same here!If this doesn't work lmk when you start the gofundme for a 6.4....
So Bummed for you. Whats your estimated cost on finding a new block, swaping parts and rebuilding?
