BaddestCross
I'm going through a similar issue with my work van right now - Ford E350 Super Duty. I've been putting off dealing with it since the weather has been cool. I replaced the fan clutch this morning because I knew it was bad, but didn't expect it to help the issue... Sure enough, the temp shot up this afternoon. I'm gonna replace the stat next and then move on to the radiator. I'm afraid that it's gonna end up being a warped or cracked head but I'm hoping for the best and starting with the simple (and cheap) stuff first.Almost always the head being cracked is more likely than the block. What scares me is that this issue started after a trail with a lot of water crossings. However, if the stop leak doesn't work, I think that's what we'll do.
Glad you found the issue... I hope you find an economical fix.
