Rick, I'll keep you informed.
Rtguy, thanks for the advice, I would have gotten the 1.75", completely unaware of impending doom. I have seen that DIY write-up, and a buddy in Chicago followed it for his install. I found a lightly used steering gear box online for $110 shipped and had it sent to my buddy to port and tap it. The only labor I will have to pay for is for welding the ram tabs onto my EVO high steer bracket. The current build sheet I have is below:
- PSC JK cylinder assist hose kit (PSC-HK2035) - $83
- PSC 1.5" x 6.75" Ram Assist Cylinder (SC2221K/SC2222K) with hardware - $196
- PSC power steering/transmission cooler (PSC-MBC110K-2) - $190
- gear box found online - $110
- misc hose clamps and such - $5
Total $584
The additional reservoir kit for $500 is not necessary unless you run a desert race rig. Also, the $1200 steering gear box that PSC sells as part of the $1600 kit does have some modifications that are slightly better than a ported and tapped stock box, but from what i have learned, you are mostly paying for the name and the custom machined aluminum parts they bolt on it. I decided that it was not worth $1200 to me, but some of you may want to just buy the preassembled kit because its easier and gives you peace of mind. I'm on a tight budget, so its the DIY kit or nothing.
