Looking good JAGS!
I have no updates. [emoji22] Ive basically been driving for work or as a taxi for daddy duties. After arriving at a work meeting this morning, I looked down. Kind of cool, so figured I'd post up. Now back to the grind.
Nobody cares Jason we just want to see new stuff on your jeep no new stuff then we don't care hahahaha
Looks like I have some investigating to do.
Lights work. Fuse "appears" ok. Fast flasher inside and fast turn signal. Not sure anyone has posted about the dash display. Figured I'd share.
Well that's a first. Don't know if I've ever seen that. I'd call on a web wheeler to help you out but.... :crazyeyes:
I had something similar happen a couple of weeks ago. Dash display read "Left rear brake light out", luckily for me, the bulb was out and it was an easy fix. I thought it was pretty neat that the display alerted me that a light was out, pretty cool feature.
With a fast flasher inside and fast turn signal but no bulb out, sounds like a resistor is a good place to start. Good luck with your investigation.
Good lookin Jeep :beer:
I have the same issue going on with both of mine right now. Left started doing it and then the right several days later. I just haven't messed with it yet since they still "work". I'm sure it's the resistors since my fuses are also still ok.
Lol. Right!?!? So I grabbed some 15a fuses last night just for good measure. And ordered a new resistor for the taillight.
Just weird with the display as it goes off every time I start the jeep. Even before I use the turn signal. I'm able to clear it by hitting the compass button on the steering wheel.
Russ has that same issue.
Ditto. Comes and goes every now and then. Often when it rains. :thinking:
Mine did the same thing. I changed the resistor and it's fine now. BUT it's my 3rd resistor...
Where are the resistors located at?
Im about a year and half in on mine. First issue I've had.
Hmmm I wonder if it has anything to do with the rain and it getting wet. When my resistor was bad I only got the first error when I pressed on the break pedal. It made me believe that the issue was tied into the third brake light.
