OverlanderJK
Resident Smartass
While I was under my jeep for the last oil change I notices just a few spatters of grease from the Rzeppa joint on the output if my T case feeding the front drive shaft.
No noises an no idea how long it's been there.
Installed a TF leveling kit about 14 months ago, or 38,000km. Jeep has 147,000 Kms on it.
I've wiped clean the bit of grease I saw to see if it comes back a I have no idea when it showed up.
Anyone here had any luck replacing their Rzeppa joint? I see Q tech and 4WP sell a kit to do so. Looks like $130 or so....keep me going until I can upgrade is the thought process.
No plans to push further then say 2.5" kit some day and only mild wheeling almost all DD.
Boot on this shaft looks fine no rips, tears, leaks, or seeping.
No cause for concern now, just want to be ready for when I need to be.
Thanks
I've never heard of anyone replacing the rzeppa. For $130 you are a third of the way to a new 1310 driveshaft from JE Reel or Adams. I would not recommend putting any money into the factory driveshaft.
