I would get the CV style. I think the only advantage to the OE style is you don't have to replace the yokes. That only takes a few minutes with an impact gun and a torque wrench.
You probably should have started with the rear first since you need that to drive.
I hear you. When the guy took the nut off of my yoke it was a little stubborn. He grabbed his puller and the yoke just fell off the shaft coming out of the transfer case. Air tools make anything look easy.
Those of you running after market shafts, are you running a 1310 or 1350 size for the front shaft? Is there any reason to run a 1350 size up front on a stock engine with a sport transfer case? Also regarding the adjustment of the pinion angle, do you want to have the pinion parallel to the ground or do you want the pinion in line with the angle of the shaft?
another way to check is to lift all four wheels off the ground make sure you put it on jack stands and the tires are not touching the ground start it up and put it in four high and idling should turn it enough that you'll be able to hear it
Started as a small vibration and within seconds a howl/grind and she was done. Clunk until I got pulled over.
