Found a great resource that has helped me more quickly narrow down some parts to compare bolt patterns, rotor specs, master cylinder specs, etc. It is through Centric's website. They are an OEM brake component manufacturer that produces and supplies a large portion of the OE brake parts. Through their catalog and reference tools, I was able to obtain measurements and specs on a large number of parts.
I think I may have found the master cylinder that Teraflex is selling as part of their 'Big Brake Kit'.
Here is the stock JEEP JK 2007-current master cylinder:
and here is the master cylinder for a 2010-2011 Dodge Nitro!
So what's the difference? Well, first, what is the same: brake line port thread sizes match; overall dimensions of master cylinder and reservoir. There is a subtle 0.06" difference in the plunger lengths, but there is a threaded adjuster in most vacuum boosters to allow some tweaking. 0.06" is not anything to worry about. Many of those adjusters can accommodate almost an inch of play!
What's the upgrade?? The bore size is 1/16" larger.
So now for some math:
The stroke volume of a master cylinder is determined by: pi*bore radius*bore radius*depth of compression of plunger
Stock JK MC: 3.14159 * 0.5" * 0.5" =
0.7854 sq in (cross sectional area of cylinder bore)
2010 Dodge Nitro MC: 3.14159 * 0.53125" * 0.53125" =
0.8866 sq in
So what does this mean? If you depress the plunger of the stock JK master cylinder 1", you move 0.7854 cubic inches of brake fluid. If you depress the plunger of the Nitro master cylinder 1", you move 0.8866 cubic inches of brake fluid.
If you calculate the increase in volume as a percentage,
that comes out to a 13% increase in stroke volume! Why is this significant? Because, ironically, Teraflex advertises a "14% increase" in fluid flow with their upgraded master cylinder!! Strikingly similar numbers, huh??
And here's the fun part: The MOPAR brand replacement master cylinder can be yours for the amazing low price of: $56.49
Compared with the average price for the Teraflex unit of $190.
I haven't verified yet whether or not this replacement includes the reservoir or not, however, most of these late model ones I've researched do. And it appears, anyways, that the reservoir for this 2011 Nitro is the same as that on our JKs, so you could reuse yours, worst-case scenario.
I'll keep it coming as interest persists... much more to figure out here
I like the potential $130+ savings already, though!! Honestly, though, I would really like to find a master with a bit bigger bore. 1.125-1.25" would be ideal, I think. But at least this is a start!!
Even if you don't decide to do any rotor or caliper upgrades, this could be an easy $60 upgrade on its own to add some good, solid feel to your brake pedal!
