Majik
But Majik is saying that the master cylinder from a 2010-2011 Dodge Nitro (not a Jeep) might be what TF is using in their big brake kit.
From my research, the 2010-11 JK has the same MC part number as the 2012-2013s. It has a 1" bore size. The Dodge Nitro MC is identical except for a 1 1/16" bore, which translates to about ~12% more fluid flow with the same pedal stroke. That happens to be the same number that TF mentions - 12 or 13% more flow (IIRC). Either way, I think the key is that they are using a 1 1/16" MC bore.
With my caliper selection, I don't think you will even have to change MC. The rigidity of a fixed caliper makes it more efficient. If you don't flex the caliper, you don't waste flow and don't need as large of a MC bore. Which is double-good because a smaller MC bore also gives you more hydraulic leverage - You get more pressure at the caliper with less foot effort.
I just got a gorgeous new pair of red powder coated calipers in a Fedex box today
