Sheaffadelic
you trim your top like mine? or shave the bolts?
Probably too low, but I got my back up camera installed today
Been annoyed with the spod location, and wanted to move the cb further from my head on the cage so finally moved it for good. Problem being is where do I put the spod till I decide on a new switch system. Blocks some of the tray, but is easy to lift up.
Put it above the rear view mirror...that's where it is on my Brute.
That where he had it but wants to move it cause his CB sits right there as well
I moved my CB further back and had it facing forward so I could see the controls in my rear view mirror
Hmm I should have thought about that lol. I was always worried on the trail with it a little further back with hitting my head on it tho....which has happened a few times before since I tend to jump into my jeep.
I'm only 5'10 but only hit my head getting in, not on the trail since I have a 5 point harness...however, I eventually replaced my CB with a Cobra 75...the PS trailcage I have let me hide the head unit inside the rectangular center beam...I think you have the Rock Hard cage with twin center bars...not sure if there is enough clearance overhead, but you could put it inside the center console or below the seat...I very much like having the switches above the mirror
I used to run a 75 when I had my 2 door and just wasnt happy with it most of the time so I gave it to a friend. I did like how small and compact it was, but I had problems hearing it most of the time and didn't want to have to add in an external speaker.
