cozdude
Guy with a Red 2-Door
It might take a few start up cycles for it to clear the cel. Just give it a few days
Noticed this today
It's hard to tell but are you saying that it's still leaking? If so and if it's not coming from the flange seal, you might have a cracked housing. Had this problem years ago, back before anyone was seeing it happen and it took me a while to find.
Well I drained the fluid to be safe...probably pointless with low miles but oh well. I wish I would have drained it into a cup or something to see how much I lost or started with. I dont know if its still leaking however, or really where it is coming from. I would think its coming from the flange seal however since there is fluid up on the heat shields near the driveshaft. Is that something easy to fix myself?
Regardless if its a cracked case or seal, you should be under warranty for that part...
I feel ya on the leaks , I've been slowly patching everything up on my jeep.
My trans leaking, front main seal is leaking, and I think my t-case is leaking too [emoji30]
With only 7700 miles, I shouldn't be having any leaks. I understand things were changed, but still.
