Still think I need to calibrate the fridge, but it did a good job over the weekend keeping my drinks and food cold while I was watching our local hill climb.
Finally found a home for the monitor which I am happy with. Have the fridge set to 31 or 29 I think. If I stop being lazy, and decide to pull apart the dash a little I may cut off the end of the cig adapter for the remote monitor and hardwire it so I dont have to have it plugged in all the time.
So did you get each other anything to celebrate?
Just run a tap splicer into the wiring behind the cig lighter...that's what I did to hard wire my radar detector. Then you'll still have use of the socket if need be.
I recently chunked my rear view mirror for a camera and tapped into the steering column for the wire that's only hot when the keys on. It was the easiest way to get the hot wire I wanted and didn't require taking my whole dash apart. I'm always afraid I'm going to break some tab when I do that and have to listen to a rattling dash from then on.
Gonna paint them this weekend if I have time, and need to figure out the hose routing for both sides for the coilover res and they will be installed. I will admit they are kinda dumb but I like how it cleans up the wheel well since I am not running stock trimmed liners.
Also in the picture it's not mounted properly.
Are you getting rid of the nav unit?
