ScoobyCarolanNC
Umm. I come from years of tuned Audi's. Y'all are crazy. On 35s with 4.88s those are solid numbers. Put it back on street tires/stock gearing & those numbers would go way up. I'm impressed.
If a programmer could yield real world results on the 3.6 that were truly transformative or even noticeable that would be fantastic. 30 hp is very noticeable. My guess is that what you pick up would be hardly noticeable and may be more placebo than anything else. I dont find the supercharger figures to be fantastic either but comparing a programmer to the blower is ridiculous.
Final numbers after custom tune are 301hp and 270lbs of torque still on 35s and 4.88 gearing.
I'll have to disagree on the Pentastar mountain pass, towing comment and the need for a supercharger. If you set it up right when you add the larger tires, like re-gear it correctly, then traveling the passes and towing will not be an issue. I wholly agree the 3.8's need the bump. The 3.6's on the other hand, I'll take a pass on the $6K accessory.
Quick question to anyone who actually has done an engine swap in their California registered Jeep. How do you get it to pass emissions inspections? How do you get it smogged? I looked into an engine swap between two different vehicle platforms several years ago. There are many rules and restrictions in California. I just don't see how an LS engine (out of a car or truck) can go into an SUV (Jeep) without getting gaffled up in breaking some smog rules. Example: no truck motors into cars, and no older motors into newer cars. Also there is that pesky bi-annual smog check. Trying to get "funnycar" smoggs is a royal PITA!!! And having to get 'em every two years definitely does suck. How are you guys that have done swaps in Calli getting your Jeeps smogged and registered?
No, it's not a Hemi or an LS BUT it's $20,000 cheaper.
Pretty obvious that there are different expectations on what $6k buys and how much HP is "enough". Most guys used to modding other cars would be happy with a 75 whp bump for $6k. No, it's not a Hemi or an LS BUT it's $20,000 cheaper.
I absolutely agree that if I had a 3.8, the investment is well worth it. But with the 3.6, there's plenty of power to go around, for what I use it for. I may change my mind at some point and consider the Edelbrock, but not until some of the issues I've read here have been cleared up.
The RIPP supercharger looks good.
I have the 3.6 - and sometimes it works. When it does, it doesn't have enough power and the economy is terrible.
The speed limit here is 75 mph. Higher is some areas. Driving under 75 is dangerous and will cause an accident. The 3.6 is always shifting into 3rd from 5th just to try to keep up with the driving lane. Forget about the passing lane. Those kind of speeds in 3rd gear get you 12 mpg, or less.
Just curious what tires and gears you are running?
I just got home from a 2500mi road trip from San Francisco to Seattle and back with a weekend of wheeling in Tillamook.
Most of the highway time was spent with the cruise set at 70-80 and the 3.6 ran like a champ. I have 37s and 5.13s and it is a great combo. Only was shifting into third on the really steep hills which wasn't very often. Most grades it would pull just fine in OD with the occasional shift to 4th.
I don't buy it.
I recently talked to someone that claimed they got 22 mph in their Unlimited Sport with 37's and 3.21's. Well, I know better than that.
Well I admit 37" on 3.21 will be slow but I'm sure they can hit 22 mph....now 22 mpg they must have Diesel with a magical unicorn pushing it.
The guys in my club got 18 to 22 running 75 to 85mph our last trip they all run 35 duratracs with 3.73s or 4.10. Meanwhile I have the 3.8 auto with 37s and 3.73, getting 13 to 16 city and keeping it at 72 and below mph. If your jeep is getting 12 you must live in the mountains and have a lead foot.
I don't see how this is better than ripp or magnuson who have proven themselves on JKs and I believe push out better numbers.
