yeah, I'm still mostly stock other than gear/tireUnmarrying definitely brings things like gear ratio and tire size back to stock. Of course, it also causes the service axle, sway bar disconnect and a whole host of other lights to come on as well being that I'm missing a lot of stuff. I may try using Jscan to correct what I can.
I agree that your problem isn’t within the section of wire under the bed. If you had a can bus issue back there you would be getting more blind spot messages and the dash wouldn’t be freaking out like it is. Your issue probably is within the radio/HIM module (not the head unit itself) or the wiring in between due to it losing power and freaking out the center stack.Honestly, I really don't think that's where the problem is for me or at least, not anymore. Tail light works just fine and I can't really see how anything back there would be affecting my Infotainment System and center stack. That said, I suppose it would be something to check but at this point and time, I think I'll try the dealership first.
I appreciate the heads upI agree that your problem isn’t within the section of wire under the bed. If you had a can bus issue back there you would be getting more blind spot messages and the dash wouldn’t be freaking out like it is. Your issue probably is within the radio/HIM module (not the head unit itself) or the wiring in between due to it losing power and freaking out the center stack.
The dealer should have a tester provided by mopar to check the connections when you take it in. I would remove the tazer and just make sure you show the advisor and the tech the video so they know where to be looking. The service axle and sway bar messages shouldn’t interfere with diag since they are on the chassis side of things where this is all body module related
Did “we?” No.Did you ever figure out what the issue was?
The passenger side tail turn signal? YES. Everything else, NO. Things were actually great up until I took this Jeep out on the New Year Kick Off Run and then, all went back to shit or at least, on the center stack/infotainment system.Did you ever figure out what the issue was?
