And after opening the carrier, I saw this!!! Damn salt !!! Are these joints salvageable? They have only been on my rig for like 2-3 months!!!!View attachment 19993
.....Are these joints salvageable? They have only been on my rig for like 2-3 months!!!!
Come on man! Those are Currie Johnny Joints, those things are going to need a little more abuse than that to call them toast :thumb: They are totally rebuildable, I would just use a light sandpaper or even a green-pad on the center hole and then learn to hose them with a good rust-inhibitor/lube spray.
...I'd flip it so the zerk fitting is up (thats how I did mine). They don't need greased that often. Pulling them out is easier than dealing with a broken zerk fitting. Or so I would think.
I know you are good with metalswhat do you use in the industry?
Not sure if it would work on those joints, but Eastwood.com makes a spray for wheels/polished metal that seals it up which may work.
Biggy, Dave, Andrew, Greg, and Mike.
Thanks for all of your input.
How do you disassemble the joints? Is a specialty tool required? If I sand it down, will there be play in the joint after that?
Also, what's the best grease to use in these joints?
I just cleaned Greg's joints on his carrier with a brown scotchbrite pad, mounted on a die grinder, and painted them black, he could probably send you pics, if ya wanna see how it looks.
2011 JKU 3.5 R.E. Longarm lift.
So you painted the entire center section while removed from the casing?
Didn't even have to take them out the brown pad is flexible enough to get down into the groove on the joint, then we coated the exposed part of the joint with corrosion x and painted the casing, the scotchbrite pad will take the zinc coating off so you pretty much have to paint them.
