Lol. I haven't measured since I added the spacer, but it's only about 3.5" lift. The 4-6" shock is Rancho's classification. I went with it because the measurements work for my setup (thanks to desertrunner's meticulous work on his rig
Yes, other than the spacer and longer shock, it's the same setup I was running. I couldn't run the longer shock until I extended the brake lines (thanks Greer!
You have to keep in mind that any lift you get ends up being about 1/2 to 1" higher on a 2 door except for maybe the Rancho Sport lift that's specifically designed for the 2 door but steel bumpers, winches, and armor will bring it down a little once the springs settle.
Build Thread - Adventures of Fiona -
https://wayalife.com/showthread.php?t=47407
