It's coming along nicely. I'll try to post up some pics for you later.
That's what I've been saying. I have no reason to make any of this up .......
Wait, did I miss something. :idontknow: :thinking: People were actually saying you made this up. I thought there were #182+ posts of "thank you for bringing this to our attention." :cheesy::cheesy:
TeraFlex is telling people that they did not make or send out a new and improved bracket to Tom. This stands contrary to what I have been saying and I'll be honest, that kind of pisses me off.
So, I talked to my friend Tom and can tell you that TeraFlex is lying and he did in fact get a new bracket from them, complete with 2 new gussets welded inside the thin cylindrical tube and he still has the packaging to prove it. I apologize for the small pics but, it was a mistake and they are all that I was able to get today...
Here you can see them through the cutout in the side of the tube...
Now, if there's nothing wrong with this bracket, why send out this new and improved one?? :rolleyes2:
Oh, I'd also like to point out that my friend got around to re-installing the bracket and, from what I could see, the sidewall of his spare is able to make decent contact with the factory rubber isolator...
However, try as hard as he had, he could only get the passenger side to lightly touch the hinge...
Unfortunately, this still allows for A LOT of jiggling just like before and it can be easily seen when you just close the tailgate. There is simply no way to get that thing any closer or, at least not with the wheels he has.
I should also note that I was over at Off Road Evolution today and saw a couple other JK's that had this same tire mount (none that were installed by ORE and with wheels that were different from the ATX Slabs that Tom has) and much to my surprise, neither of them had spares that sat firmly against the hinge and both jiggled just like Tom's when you closed the tailgate. I guess there are other people out there without the kind of "common sense" that some of the trolls here would suggest that everyone should have. :rolleyes2:
I know, was just messing with you.
And yep, TF is getting exposed for telling customers two different things not realizing the customers are talking to each other. Though will also say, MANY companies do this. Doesn't make it right though.
If one of those JK's there was all silver with 37"'s on black wheels it's mine. As I ordered the ATX Slabs yesterday hopefully by the time they arrive I will gain some of that "common sense" so I can adjust it later. I didn't trust my common sense when I installed it so I followed the instructions instead:
" 6. Install the spare tire carrier and tighten the lug nuts, using caution not to pull the sidewall of the tire too tightly against the carrier. If the tire sidewall hits the carrier during lug nut tightening, remove the tire, loosen the 7/16" bolt and nylock nut, and slide the outer tube piece farther outward to create room for the tire."
"NOTE: If the spare tire appears to lean toward the from of the Jeep when installed, it is adjusted too tightly against the tire carrier and needs to be adjusted outward slightly."
BTW my isolator looks the same as the pic above and the other side brushes the carrier. Damn internal struggles vs instructions.
Well now I'll have to pay more attention as I'm sure the Slabs weigh more than the Methods.
I'm about to order mine, just gonna use the stock carrier.
Just note the stock carrier is not rated for more than 35" I believe.
I took some photos of the welds on the carrier that I have received earlier last week:
I will still be happy to use this carrier but I will pay a lot of attention to the weak spots that have been discovered.
This is why I had to consider using the Teraflex carrier over a bumper carrier or a cage.
I still believe that it is stronger than the factory carrier. That doesn't make me fanboy.
And now I want to apologize to all of those who felt I was jumping the gun by making my very first post in this particular thread here.
I didn't feel very welcome here just because I had another point of view for said reasons.
While doing my research on a new product for the Wrangler Google pointed me into your direction. I was glad that I had found a first hand experience about a potential risk before I was going to buy the carrier. But your thread did not answer what I was wondering about: In order to determine upfront if the carrier works for me, my mission was to find out if I was able to avoid such a crack. Again, my choices of tire carriers are limited.
A troll would have questioned you for no purpose. That said I'd prefer "devil's advocate" over "fanboy" or "troll" as I was only interested in discovering possible reasons that lead to the crack.
Judging from the photos of both the Teraflex carrier and the factory carrier that I have seen in this thread, I believe that leaving a gap between tire and tailgate can be fatal.
I was told that I am arrogant and condescending if I assume that this is common sense. So why shouldn't it have been part of your initial post to remind people of what should be common sense if it was your ONLY point to warn potential users?
Different mindset, never mind.Apparently, I lack your sense of common sense and have no idea what common sense you feel that I should have been pointing out.
