GraniteCrystal
Yeah, mine said the same thing. I did. Instructions are wrong. Been one of those days.As my high school wood shop teacher used to say, measure twice, cut once. Applies to drilling too. [emoji6]
Ok, need some help. Did some more troubleshooting tonight. The carburetor has an adjustment screw to change the amount of gas coming in. Protocol calls to tighten the screw all the way, then back it out two full turns. Turn on the Jeep and then tighten the screw back down until it starts to stall, then back off till it runs smooth.
Here is the weird part. The Scrambler won't even start unless the screw is all the way tight. It barely idles even then and as soon as I back off the screw to give it more gas, it starts stalling out.
Does that make sense?
Also note, I took the top off the carb to give it unrestricted air. So should have plenty of air going in yeah?
Here is the little flathead screw I'm adjusting
Sent from my Pixel using WAYALIFE mobile app
Yeah, even when I first bought it I had to pump the gas a few times to get it started. Would that point to a flooding situation too? Tips on next steps?Sounds like maybe it's flooded. When you try to start it, press the accelerator pedal all the way to the floor. That will open the butterflies and let max air in.
Thanks! It's a journeyYou will love that thing when you get it going. Why did I sell mine??!! Looking good GC!
The one time I disconnected the fuel from the carburetor, started the Jeep for about 1-2s and there was this much fuel in the bag. Seems like it's getting plenty of fuel right? I meant to check the internal fuel filter on the carb last night and forgot.Have you checked actual fuel pressure yet with a mechanical gauge? I don't know what spec is, but that may give you an idea. They make them that you can put in line and just leave them there even.
No change in behavior when I take the air filter completely offAir filter still looks really dirty. Maybe it's just the photo.
If you have an electric choke, make sure it is operating properly.
