Here is the internal fuel filter. Looks pretty clean yeah?
Looks fine.
As in actually unscrew the white plug from the engine?If you remove the air filter and crank the engine, you should be able to visibly see if fuel is getting into the engine. Looking at the bag, it looks sufficient. As suggested above, you may want to pull a spark plug or two just to make sure it's not flooded.
If it is flooded, web said to start it with pedal to the floor. Just did that and it did start, with a big black cloud.Yep. Either a 5/8" or a 13/16" socket. Do one at a time so the right wire goes back on the right plug. You may need a specific length socket to make sure it goes all the way down. Most tool kits include them now anyways.
Also noticing that if I pull the linkage all the way back, the butterfly valves only open to here
But I can open them by hand to here
That's definitely a possibility but previous owner said he already did that. Here are some pics of the jets. Can you tell?Missed this thread so congrats!! That is a clean looking CJ. Good find. Subscribed!
I remember being in the exact same shoes as you are haha.. I could drive mine but it just never ran well. Mine would "pop" under acceleration. That was a timing issue and sounds similar to something you described. Didn't see if that had been checked.
I ended up trashing my electric choke and swapping it out for a manual choke, but don't think that was necessary looking back.
And just throwing a Hail Mary out there, I saw the Jeep was from Miami. Maybe the carb has the same jets from back then and needs to be re-jetted for being at a higher elevation now? I'm no expert but maybe it could help?
Sent from my Pixel XL using WAYALIFE mobile app
Its been a real long time, but if that is the throttle linkage that will only open the plates that far, that seems extremely restrictive to air flow. You mean throttle to the floor and that's as wide as they will open?Also noticing that if I pull the linkage all the way back, the butterfly valves only open to here
Yeah. I thought the same thing. Working on adjusting that today.Its been a real long time, but if that is the throttle linkage that will only open the plates that far, that seems extremely restrictive to air flow. You mean throttle to the floor and that's as wide as they will open?
Sent from my SM-N910V using Tapatalk
Good luck, because I hate to see a jeep like that sidelined. I miss my 83 cj-7 laredo. It was my first jeep, and I was waaaaay too young and stupid to appreciate it. 30+ years later and I still kick myself for it.Yeah. I thought the same thing. Working on adjusting that today.
While waiting on insight for my carburetor problems, I took the time to install a new shifter boot.
Old
New
Weber 38DGASMI'm not too familiar with the carb, but typically the choke will only open to a certain point then it opens all the way based on temperature, etc. Do some research on that CARB's choke circuit before you start adjusting too much. What kind of carb is it? I may have some old books I can look at.
Weber 38DGASM
