Scott, a couple things to consider. I don't disagree with purchasing smaller jets to lean out the mixture, however, if it has the OEM jets in the carb now, it shouldn't be running abnormally rich, something else may be the issue. It could be as simple as an air delivery problem as well. If you get the engine too lean, you could do internal damage. So really make sure you do a lot of research with what you already have or what you decide to buy. Also, if I were you, I would buy a timing light and see where the timing is at just to make sure that is in check as well. It's cheap and easy.
