DMF
One swift delete and IP block will shut this thread down and prevent Lucas from accessing this site ever again....ah the power the administrator wields is fascinating.
I mean, he sounds so cool at d0xing hope he can find ways around when his IP shows every device he used to access this thread or site in general.
Wifi changes the ip every time you connect and reconnect to the Internet
Doesn't matter if you always use your home internet (wifi)
Edit
Before some one tells me I'm wrong
Here is this for you
http://classroom.synonym.com/wifi-change-ip-17586.html
Your welcome
I believe you misinterprit this webpage Brankzie. They are referring to a local IP which it doesn't matter what IP you have today or tomorrow. You can update and change your local IP as much as you want, when you want but that IP will need to translate over to a Public IP, a Gateway that your ISP owns. This Gateway rarely gets changed. Go to www.whatsmyip.org and see what your Public IP is. Try it again tomorrow and the next day. Or even a month from now. It will probably be the same IP even 6 months from now.
