Hey guys. Thanks for all of the patience and support. As you all know, this project is a research project, and sometimes during research, you find that the direction you were originally heading runs into an issue. One issue I've encountered involves the available thickness of the test adapter bracket I've machined for the caliper. The rotor I've been working around meets alot of criteria that needed to be met, however, because we are using a fixed caliper, the offset (aka rotor hat height) of the rotor dictates the caliper position. And with the caliper in the correct position, the available space between the mounting tabs of the caliper and the mounting holes on the knuckle is only around 0.200".
After much analysis (and thus alot of my delay in releasing updates), I've determined that I do NOT think that this is enough material to support a caliper trying to suddenly stop a 120+ lb 37" wheel/tire combo, spinning at 70+mph. The massive forces involved have the potential to deflect the adapter bracket at this thickness, and that's not a good thing. Now, there are some adapters out there in this thickness range, but they are mainly being used on lightweight muscle car wheel/tire setups that may only be 50 lbs total.
I simply don't like this for use on our rigs. I think that this is one of the issues that has prevented the mass release of Big Brake Kits for JKs from tons of manufacturers.
The JK uses a PITA combination of a very shallow rotor with oddly spaced mounting points on the knuckles. This severely limits my options. HOWEVER...there is good news
I believe I have located a different rotor that will allow me to increase the caliper adapter/bracket thickness to around 3/8" (0.375"), which would be perfect for our use.
I hope everyone understands that this is why I haven't just thrown the part numbers I've experimented with out there... I know that there are some that would rush out to buy parts, and then be irritated when I was forced to change direction. I will already eat the cost of the rotor, possibly the caliper, and maybe even the Reid knuckle I machined.
In an effort to make this phase of the project work, I even went so far as to mill down the thickness of the caliper mounting tabs on the knuckle. If I mill 0.150" thickness off the outer side of the mounting tabs on the knuckle, then I can add that thickness to the adapter bracket. But I realized that this is moving the project far away from even more listeners, if I continue to machine the knuckles, etc trying to FORCE the rotor/caliper combo I chose to work.
And I really want to make this as close to a bolt-on fitment as possible...to make it available to more people!
So, I'm rethinking the direction of the parts selection and going to see if we can make this work with NO knuckle modification. And I think we can... :clap2:
So...the point of my ramble is: Let me spend my money to make this work. I know I'm going to eat some of the mistakes I make along the way, but I'm really, really close to finding the magic combination. And I would much rather only one of us loses a few bucks instead of several of us. So, please be patient. I will continue to post updates. I hope that I haven't irritated too many of you with the slow progress. I really, really want to contribute this back to everyone that has been so supportive...I just want to contribute a QUALITY solution, however...not just a half-assed fix. I look at it this way: if this parts selection process was simple, there would be 20 different JK brake upgrades out there, right?
The final pieces of my complete JK makeover project just arrived today from Brown Santa, and are sitting in the garage, so I have PLENTY of inspiration to bust my ass and get this brake upgrade finalized!! I hope a few of you continue to follow...
