did you ever get the mounting brackets made?
Yes and no. I mocked up the brackets out of lexan. The mock up was a great idea, too, because I found one key hitch in this build. To some people, like myself, they are gonna say "no big deal", but others are gonna probably say "that is too much for me to deal with". It appears that to mount these calipers and perfectly align them with the rotors, ONE of the factory caliper mounting holes on the knuckle needs to be slotted about a quarter of an inch. I have a new set of Reid Racing knuckles that is going on with upgraded ball joints, so it's not an issue for me, but for alot, it might be a deal breaker. The reason has to do with the height of the built-in caliper mount on this particular caliper. It actually is a tiny bit too tall. So... I am going to take one of my factory knuckles to the machine shop, put it in an end mill and slot one of the holes, bring it home, and see how it works. It will take the shop no time at all to do, but I know alot of people are going to say "I'm not taking off my knuckles to do this...I want a pure bolt-on upgrade". And I totally understand that perspective. I would prefer it that way, too. If it works (and I suspect it will), I will bring the Reid's over and perform the same mod.
And to answer in advance some replies I know I'm going to get from this: 1. yes, the iron knuckle is PLENTY thick at the area I'm going to slot it. Nearly a full inch thick. 2. The tiny space in this 'slot' that will be open next to the factory caliper mount bolt will be filled with a small steel crescent-shaped dowel pin. This will lock the bolt and prevent any chance at sliding. (Even though sliding is nearly impossible because the other caliper mount bolt hole will be fixed, not slotted. 3. The Reid knuckles are even thicker in this area 4. I'm still researching other alternatives, but I think this is going to be the only way to make it work.
I hope everyone can picture what I'm describing. It's just like the slotted adjustment that you have on a mounting bracket for an engine accessory, like an alternator, on an engine that doesn't use serpentine belts. The alternator has a fixed pivot bolt, and then one bolt in a slot that can pivot back and forth and be tightened down to lock the alternator in place with the belt in tension. Except the slot I'm speaking of is only an extra 1/4" added to the standard bolt hole. That's all I need. And with the 'dowel pin' (for lack of a better term) used to fill the empty portion of the slot, the caliper won't be able to move. The rest of the mounting adapter is steel plate to provide the right offset and align the caliper with the rotor perfectly.
Everyone following? I know that alot of people are gonna be bummed by this requirement. To fit a 14+ inch rotor in a 17" rim, using OEM parts, I knew there had to be some minor issue to address somewhere... In fact, I'm kinda proud because both Wilwood's ~$2000 front brake kit and Brembo's ~$4400 front brake kit both state they require an 18" rim. That rim requirement would turn alot of people away, I would imagine. It appears that I will be able to make this setup work with 17" rims, with the same (actually a touch bigger) rotor size as the big companies and calipers with the same piston sizing. Oh, and I don't think we are even going to have to touch the master cylinder! Forgot to mention that
I will keep you updated...
