Majik
Sounds solid to me. Just need to paint "Majik-wood" on the side now.
LOL. That just sounds soooooooo bad..... :cheesy:
I've been doing alot of digging lately, trying to reassure myself that my caliper selection is valid. I found a nice piece of info: Wilwood makes a 'big brake upgrade' for the JKs now. It's cheaper than the $4400 Brembo upgrade...but it still costs about $2000 just for the front caliper and rotor. Nothing else. Still 'ouch' in my opinion. But here's the reassuring part: they just so happened to select a 4 piston caliper, using 44mm pistons, and a 14" rotor!!! The caliper I'm working with uses the exact same piston sizes, and the rotor is the same size, too! They also advertise that their system, because of the caliper selection they use, does not require a master cylinder upgrade! (Which is the same thing my calculations indicated for a 4-piston, fixed caliper with 44mm pistons.) This is EXTREMELY reassuring info. Now the only thing to determine is whether or not their upgrade's braking improvement is strictly due to the larger rotor, or if the fixed 4-piston caliper design actually adds power vs our stock floating piston design. On paper, the effective piston surface area is not any larger with their fancy, fixed design. But, as I've discussed before, the question is whether the more rigid, efficient caliper, combined with the much more even application of pad force due to the multiple piston design actually adds braking power. My suspicion is that yes, it does, and that it may be more noticeable than a simple comparison of caliper piston sizes might show. If it didn't add performance, why would auto manufacturers use them on their 'performance' models, like the SRT8 packages from Mopar, or the GT500 package from Ford, when they are in the business of making money? If a cheap floating caliper with one or two pistons with EQUAL piston surface area to a 4-piston caliper fixed caliper provided the same performance, and give them the same 60 to 0 times to post, I highly doubt they would fork out 3-4 times the price for a fixed caliper.
Guess it's time we prove that ideaThe pressure film I mentioned last week is being shipped and should be here any day. Then maybe we will have some comparisons of stock vs new caliper pressure distributions to view! All in all, I am going to continue with the 4-piston fixed caliper build, after coming across applications like the one from Wilwood that I mentioned above. I think we are on solid ground.
I subscribed to this forum for this thread. :clap2:
Looking forward to the progress. Subscribed!
No sig yet - I'll get on that. Standard stuff: 37's, LS V8, etc. :beer:
Welcome!![]()
El Jeffe welcome over here!!
Beefy caliper = heat dissipation
