Does anyone know, when I pulled out my front passenger seat there was no wires at all to unplug, can I cycle my ignition?
What? I’m not following. Are you asking if you can start the engine with the passenger seat removed?
Shouldn't matter if there are no wires.
I tapped in to the cig lighter for mine with no issues.On my cb wiring, this inline fuse that came with the cb has a 3A 240V fuse in it
The wire kit I used for power has a 10A fuse
And I think the cb uses 1.5A
So I assume I’m good or do I need to know how big the lighter fuse is or amps but I am not sure about that other than looking at the fuses
You should be good. The lighter is probably a 15A so the 3A should blow first if there is a problem with the CB. Unless it's a dead short in the power wire. Then you'll probably have 3 fuses to replace.On my cb wiring, this inline fuse that came with the cb has a 3A 240V fuse in it
Works for meOk cool I’ll get it wired up then when your feeling better we can tune the antenna. Thanks Andy
I don’t see why not. I run K&N filtered for both cabin and engine. Cabin filter usually gets dirty quick so I opted for washable one.
Not sure if that one fits 2009
https://www.amazon.com/gp/aw/d/B017J19R06/ref=ya_aw_oh_bia_dp?ie=UTF8&psc=1
I believe if you go to K&N website, you can find the correct part number, don’t forget to get the cleaner. There’s 2 different cleaners, for cabin and engine.
Does anyone know since I don’t have a cabin air filter behind the glove box if I can add one? I can’t find the thread about it
