Sharkey
Word Ninja
Perfect. Thank you!From the switch pros install video. White wire with brown tracer from the fender lights.
Yeah true. But Iāve never seen anyone actually use one mounted there before.Honestly, itās a tight fit. I wouldnāt want to run it for prolonged periods without popping the top on the ammo box. With the top popped though, it should have plenty of airflow. Canāt be any worse than the ones Iāve seen mounted in the old rear tub cubby pre-floor subwoofer.
Nice job my friend!Been too hot/smokey and Iāve been too busy. Took the morning off to get the ARB Twin mounted and finish the modified harness.
View attachment 365333View attachment 365334View attachment 365335
(Sorry about the pics, apparently I was using Bruteās phone).
All that is left is to route my harness up to the battery and connect the leads. At least for now, Iām going to use the OEM Aux 4 to power the ARB switch in the back. That way someone walking by can turn on the ARB just for the hell of it. But, I can still set the unit to work with the ignition on when I want to (at camp or on a trail run).
Thanks! The crappy thing is I canāt completely finish. My 0.5m ARB stainless braided line still hasnāt shipped. I may see if I can source something similar through a local mom and pop that makes lines.Nice job my friend!![]()
I use a hydraulic shop on 50 in Carson City to make my lines. They'll make it for whatever length you need and while you wait. Of course, I'm sure there are shops in Reno as well that you can use.Thanks! The crappy thing is I canāt completely finish. My 0.5m ARB stainless braided line still hasnāt shipped. I may see if I can source something similar through a local mom and pop that makes limes.
Good to know. Iāll shoot you a text to get the name and probably pay them a visit sooner rather than later.I use a hydraulic shop on 50 in Carson City to make my lines. They'll make it for whatever length you need and while you wait. Of course, I'm sure there are shops in Reno as well that you can use.
Hydraulic Industrial Services. They're on 5248 US-50 in Carson City. Price should be no more than what you'd pay to get it from ARB.Good to know. Iāll shoot you a text to get the name and probably pay them a visit sooner rather than later.
That works tooā¦thanks!!Hydraulic Industrial Services. They're on 5248 US-50 in Carson City. Price should be no more than what you'd pay to get it from ARB.
I heard there are meds for that...Thanks! The crappy thing is I canāt completely finish. My 0.5m ARB stainless braided line still hasnāt shipped. I may see if I can source something similar through a local mom and pop that makes lines.
I wonder if you have a blown relay for some reason. I was fighting that on the silver Jeep. It kept blowing relays and there was absolutely nothing that would cause that wiring wise. Itās a pain in the ass to check though since you have to disassemble the whole thing.Well. Hooked up the wiring today. What a shitshow. Only one of the compressors is working. That at least tells me the ground is fine. Now I have to chase down what is going on with the other tank which is going to be a bitch. I spent a lot of time running the wiring through the frame and pulling the actual compressor out is a PITA!
On top of that, Iām getting a check engine light now. All I can think of is that the spot I used for a ground next to the battery was a āno-noā for some reason. Is there any different between the three found posts closest to the windshield and the single one more forward that is close to the air intake (thatās the one I used).
Is there a way to check codes on these without a scanner (like the old key dance on JKās)?
Fuck I hope not. Literally would have to uninstall the entire thing. Iām hoping that one of my connections to lengthen the harness wasnāt great. I think I might be able to at least get to those to check.I wonder if you have a blown relay for some reason. I was fighting that on the silver Jeep. It kept blowing relays and there was absolutely nothing that would cause that wiring wise. Itās a pain in the ass to check though since you have to disassemble the whole thing.
Lol thatās my life. I would guess itās a bad connection. Hopefully that didnāt blow a relay though. The relays are hard to find in stores too. Itās something I would buy a couple extras to have on hand just in case. I couldnāt find them in store.I seriously thought about hooking it up before I installed to make sure it worked, but figured itās brand new so should be fine.![]()
What do you mean that only one of the compressors is working? How can you tell? As far as the ground, no ground should cause an engine light.Well. Hooked up the wiring today. What a shitshow. Only one of the compressors is working. That at least tells me the ground is fine. Now I have to chase down what is going on with the other tank which is going to be a bitch. I spent a lot of time running the wiring through the frame and pulling the actual compressor out is a PITA!
You can hear the twin when only one is working and you can also feel it in the intake for the compressor. Itās noticeable when one is not working.What do you mean that only one of the compressors is working? How can you tell? As far as the ground, no ground should cause an engine light.
