Jabberjaw
I’m flush mounting it into the face of one of the boxes on my decked system. Basically where the arrow points, but probably on the other side.
That's a pretty cool looking switch. Didn't realize they made something like that.
It’s definitely not high quality and it took some searching to find. I pulled the cover and put it on the ARB body. We will see how long it lasts. I’ll save the ARB cover just in case.
Update on the periodic blinking rear locker indicator. Tech thinks it is a programming issue. They are driving the Gladiator with a computer hooked up to it to see what they can see.
Here are a couple of better pics. I’ll be mounting it vertically and I have a proper horizontal switch cover on the way.
This thing is very solid, and the switch should be less prone to accidental activation given the recessed mounting.
Your dog looks unimpressed...
I installed some tie down rails on the Decked. Very helpful for keeping stuff in place and the fridge fits perfectly sideways in between them.
Looks good. Is that something extra from Decked or something you figured out on your own?
Step one tonight. I cut in the panel. Tomorrow, I’ll mount the twin. I probably won’t get to the wiring until later this week.
Anyone know of a good wire to splice for the switch led?
Do you think the compressor will get enough airflow being in there?
From the switch pros install video. White wire with brown tracer from the fender lights.
Honestly, it’s a tight fit. I wouldn’t want to run it for prolonged periods without popping the top on the ammo box. With the top popped though, it should have plenty of airflow. Can’t be any worse than the ones I’ve seen mounted in the old rear tub cubby pre-floor subwoofer.
