Teaser shots. I have to post up more tomorrow. Difference between standard arms and the long arms is unbelievable.
Much better. Looks great.
Definitely post some more pictures
Your photographer need help with proper lighting
Nice! Congrats to you :thumb:
Looks sweet Jerry!
I would be worried about that jam but bolt Jerry facing down like that on the arms. Might want to flip that up top
I hear you. The problem is that the grease fitting on the fixed end will be completely hidden. If that was the case, you would have to completely remove the arm to grease the upper (frame end) joint.
With a 90* zerk you wouldn't have to. Based off the pic it looks like there is plenty of room. If not then easily jacking the Jeep up a little to let the axle droop would allow access
You can see how far the LCA is moved in this first pic. The bolt in the middle of the photo is the old LCA mounting hole.
Looking from the front over the axle to the driver's side mounting bracket
You can see in these next 2 photos how the front upper rear CA joint is vertical instead of a horizontal one.
