Today is a special day. Today marks 6 years with Knuckles. Man how he has grown up
Well just scheduled knuckles appointment with the doctor to get the airbag recall done. Also asked that they look at my Cats and replace if needed. I believe they are clogged based off a back-pressure test and using a pyrometer to see the heat difference. The temp difference should be 100* cooler before the cat than it is post cat. I'm currently reading the opposite
Any codes? Are you still within the emissions warranty?
Well slowly putting together everything I need for a hydro assist set up. Purchased a ported steering box from Hinrich a while back and just today grabbed a ram from tgoss for a great deal! Now I just need the pump, reservoir, and lines
[emoji19]
I know right!Cool it is about time you start wrapping up this upgrade
Thanks David!
Are you going to do the PSC High volume supply line or sticking with the stock one? Jim did the high flow one said it helped with the low speed turning.
Wow, the person who posted that is oblivious to the real purpose of a Jeep Wrangler.
