They are a pain the ass because the rod rotates down and the boot pulls the spring off. They make a flat cup washer that replaces those dumb boots.
Sent from my VS985 4G using WAYALIFE mobile app
Mines a synergy tie rod too. You've seen it flex out.
Yea new ends will be $30 a side so I will get them and hopefully they come with a better design. We will see.Think they're like 20-30 bucks a pair. I got tired of fixing the spring plus it helps keep the hydro steer cylinder from rotating along with the Rod.
What dynatracs are you referring to?
They told me that they redesigned it but we will see.
Looks the same to me. I've had mine about 2 weeks. Here's a pic, (drag link, not tie rod), the spring isn't seated in the right spot just because I haven't set it up yet.
I just purchased and installed a Synergy tie rod and drag link... The manufacturing date on the tie rod was October of 2015 and had the semi-translucent boots and spring retainers. The manufacturing date of the drag link was June of 2016 and included black boots with a different retaining device... It's hard to explain and I don't have a picture at the moment, but it is a flat coiled wire (think of a retaining ring that wraps around itself one full circle). If the difficulty of getting it seated is any indication it should hold up better than the spring.
I wasn't upset about getting the "old" boots because with hydro assist on its way this is the route I am headed with the tie rod as well. I had to do some serious looking as the low misalignment boots are on back order. Called and emailed everywhere, included Synergy directly, and finally found them right here in my own back yard (Trail Jeeps) :doh:. There are rumors that Synergy is coming out with a new version of these as well which seal better, but I have found with most manufactures, waiting for "new and improved" versions is similar to waiting for the second coming! One in the hand and all that...
EDIT: Almost forgot! Nice build!
Fuck my bad! I had ball joints on my mind.
These solved my problems with that same issue. 10$ a pair. They actually snap into place so the they have a decent seal on the tie rod end.
http://www.polyperformance.com/Syne...=PPM-4131-10&gclid=CP2flbqN988CFUJqfgodCUUDqg
I just dealt with synergy to warranty their lower ball joints. No problems with them. I just had to email them the original invoice, which of course I didn't have. But Offroad warehouse had a record of it on my purchase account so they sent it to me. Synergy sent me new lowers and requested that I send them the 7 month old ball joints I wore out. They even put a postage sticker inside the package pre paid for the return trip. I actually only had one lower that was worn out, but I was able to convince them that if one was bad the other one surely needed to be replaced.
Do you remember if you posted where you got it from in this thread? It's probably quite a few pages back even if you did lolMy problem is I don't remember who I bought it from [emoji23][emoji23] maybe they will not need the receipt and just give me a discount on a new set which I'm fine with.
I got the same ones.... They work great and no more rotationThese solved my problems with that same issue. 10$ a pair. They actually snap into place so the they have a decent seal on the tie rod end.
