Clearskies
I had a couple of issues as you know, one was with the PSC bracket, the way it mounted I ended up when I was full passenger I was hitting the bracket with the tie rod. Judging by the pic you may end up with the same issue. Maybe that's the angle you were talking about. When I mounted the ram bracket on the tie rod I turned full passenger with the ram all the way in and that seems to give me full range of motion.. Maybe that will work for you. You can measure the travel of the tie rod and determine how may inches travel lock to lock you have. hopefully the ram has the same travel.
