I think that's the way to go Ed. But I would see if you can get some old D35's under there first and get like a 3.21 gear set before you do it. Maybe even go with a 6" lift on stock ca's with the stock drive shafts. You'll be all set up for the blacks and reds. Oh and I almost forgot throw a body lift on there like a 1.5"
Sent from my SCH-I535 using Tapatalk
I just ordered the Artec truss and have the gussets already. I mainly want to build up the D30 because I'm installing a locker in front. Some people go with tubes but IMO the truss will be stronger.
Check with Globex on the gussets and truss. They keep those two in stock and as you know, they stand by their work.
Just my :two cents:.
Ah yes to be apart of the red club. Lol just to be clear on that I wouldn't have done it if Nate hadn't reassured me that it was doable and I'm thinking that with it cleared at the top of the rocks has changed it more to a black with a red line. As for the 35 37 thing as for now 35, s was the look I wanted but who knows that may change in the future
Tom
The truss and gussets won't protect the r&p gears inside. With as small as that pinion gear it will be prone to braking if you lock it andgive it enough throttle.
Tread lightly my friend! :thumb:
Btw do you have a rear locker?
Nate, I apologize for hijacking the thread. I got caught up on everyone talking about upgrades. I know so many of you are very experienced & I guess I couldn't wait till the campfire on the 14th to pick ya brain. Lol.
Ed, kp and I did both agree to be apart of the shinanigans pf the thread remember. So we atleast gave warning of the impending hijack :yup:
Sent from my phone?
Just like the guys running D30's with 37" and 40" tires, not worried about the R&P. I'm only running 34's. Hopefully if anything gives it will be the stock axle shafts which is an easy fix. I'm just trying to make the front toothpick (D30) a little stronger. For the cost of the gussets, which I already have, and $90 for the Artec truss (no cost for the install), total cost $160. IMO its money well spent to make it stronger. Eaton eLocker is $750 w/bearings and shims after military discount. Made the decision to go this way after months of talking to other members, shops, reading this and other forums. Important part is to keep the stock axle shafts. I'm also running 4.10's. Won't be doing any reds, but will feel a lot better running blacks with this setup.
No rear locker yet...my bank account will only let me do one axle at a time.
may i suggest doing a rear locker first. if anything adding a locker to the front will make the R&P weaker since it is smaller. plus you may use the rear more than the front. :twocents:
It won't make the R&P weaker, it will simply expose the r&p to more torque forces when locked.
We're all jumping the gun here. If he drives smart he should be just fine. I however like to hammer a little bit so yeah........
Steve I got a room in my basement for ya for 500 a month. Anything to get more Jeeps in my driveway :bleh:
