Another update I'd like to make is in regards to the sway bar links. While waiting for the shop to finish up their gear and driveline work, ACCUAIR sent me a new set. Actually, 2 new sets, one that's heavy duty, adjustable and similar to the front links on the JT now and one that looks like OEM but longer.
Here's a shot of the rear links with polyurethane bushings that came on the JT and always clunked from coming loose.
No matter how much I tightened the bolts, they kept on coming loose - EVEN WITH red loctite.
I was tempted to install the HD adjustable link (and may still down the road), I decided to install the OEM style links first. Me personally, I like how they have bonded rubber bushings on one end and a sealed TRE style joint on the other. Assuming they hold up to wheeling, I think they'll be a better and maintenance free way to go.
While I did get new links for the front as well, I decided to keep the quick disconnects on for now and mainly because this JT is not a Rubicon. If it were, I would have installed the new fixed links. If I can get my hands on another sway bar disconnect, I'll definitely swap them out.
