Wethy
It's the same rail, no holes but nothing a drill can't fix. More than likely I'll bolt it to the top as well. I'll be using best top uppers as they are a lot cheaper. The other issue is the gap between the front door and the rear upper since the B pillar was removed.
However I'm going to buy replacement pillars and cut and fit to sit on top the bed side I'll just mount them to the factory cage like a door surround.
In theory I think it'll work just fine.
Don't see why not but sharkey does have a good idea, 1/4" or 3/8" lexan or plexi would work and aid in visibility. And if you didn't want it to stick out you could paint a pattern around the outside to mimic half door uppers. And add a rubber gasket to help with waterproofing or something
