Oscar's No Build Thread
Amazing! Nice work!:rock:
Thanks! I enjoy designing and making my own stuff. This project was pretty straightforward and I’m real happy with the results even though I didn’t use the rear spacers. I’m going to wait until the new tires go on and see how it is.
Lol got to work with what you got good work finish looks pretty good in the images
Sent from my LG-TP260 using WAYALIFE mobile app
True that! If I were to turn them on a CNC then the CNMG would do the roughing followed by a DNMG for finishing. Being that I turned them manually, I wasn’t really concerned about tool life and the CNMG was producing a nice 125 micro-inch finish.
I would have went the same route
Really cool to see. Not many people would even think of making something like that themselves, NICE WORK!!
Thanks! I know that I could just buy this stuff for $150. I just can’t see doing that when I have the means to do it myself. For me it’s a hobby and I enjoy it!
I couldn’t leave well enough alone:
I made additional 1” spacers for the front so I can add the rear spacers and keep the same level stance. Still need to make extensions for the bump stops. I should have it all installed this weekend.
Lol I was wondering when you were going to go ahead and try to perfect your work. Machinist are never satisfied with their work always looking to improve even the smallest things
Haha, it’s like you know me even though we’ve never met! I just call it OCD 🤣.
That's really cool! Nice work[emoji106]
Thanks! Speaking of nice work, I haven’t seen any pictures of your rig outside the garage yet [emoji848].
I pretty much finished installing my DIY lift:
I’m really happy with the results. I ended up 2 3/4” higher in the front and 1 1/4” in the rear. My favorite part is how level the Jeep sits and as a bonus, my head lights actually illuminate the road!
Here is a shot of how the front looked after adding an additional 1” spacer to the spring and bump stop:
And the rear with the spacer added:
I did run into a couple of snags. As a testament that I completely designed the lift myself, I completely screwed up the rear bump stop extension:
My intentions were to fasten it with one bolt, through the center just like I did on the front. Well, that’s not possible since the perch sits tight to the axel:
I will need to redesign that and make a couple new parts 🤬.
The second issue is that both the front and rear sway bars are down well past level:
I’m thinking that I’ll modify the links to make them longer. I’m also going to design and make disconnects for the front.
Anyone need a pair of 1” long bump stop extensions? They would work on the front only. Free to a good home:
I will need to redesign that and make a couple new parts ��.
I would gladly pay you for them....let me know 81005.
Whipped up some new rear bump extensions:
They mount on the rear jounce perch using existing holes in the perch:
Some measuring shows that I should extend the shocks and brake line brackets. That will be the second part of this project.
