Ouch, that sucks Mark. It’s shouldn’t be to bad of a fix. When I cut mine lines, I leased a flare tool from autoparts store. You can also buy one, I think they are like $20 on amazon.
Also picked up one of those to cut the line. I am sure you have plenty of those cutters laying around.
Looks like a good time to install those extended brake lines, and ditch the drop brackets. Be careful with those cheesy flare tools, make sure it clamps on the line good. I think it took me two tries to make good flare. You need to make a double flare. Factory hard line is 3/16”, your auto parts store should carry the flare nuts as well. I think you will also have to scratch off the protective coating on the hardline in order to fit the flare nut on there. Just don’t be like me and try to grab it with pliers if it gets stuck on the line, they are pretty soft.
