Glad that I was able to assist. Sucks the hole is oval but squeezing the flush mount plastic cap wasnt to hard to fit in. I do plan on finding a rubber replacement once I come across something that will fit.
Paying it forward - 5/8" rubber hole plugs
Come on now, you've had a whole 3 minutes to update and program that beast of yours, we want to know if you see any difference. Careful, it just might suck you into the seat,lmao
We are Jeep..Resistance is futile..
Does the new exhaust sound good?
I personally like my exhaust but do recommend it be welded and not use the clamps provided. When installing the Poison spyder evap skid plate, I had to cut, flip and weld the bracket to the frame. My wife would like it to sound louder but ridg3runner over the weekend drove with me and he thought it sounded great. Over all rating good along with easy to install if you use the provided clamps.
Try airing the tires back up to a pressure that shuts the light off, then reprogram for a lower pressure.A great improvement from stock. But the tire pressure light is still on!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :naw:
Try airing the tires back up to a pressure that shuts the light off, then reprogram for a lower pressure.![]()
The exhaust sounded good but the tires sounded like a 747 with a gull stuck in the intake,lmao. To each is own on that one.
I don't have the sensors in my tires anymore, plus when airing down the tires I dont want the low tire pressure to come on. I however did call Superchip and they said I should have the option to turn that function completely off. I'll have to go though the menu tree again!!! :crazyeyes:
You have to clear the code first, then apply your setting from the programmer. The setting will not take until you get the light off.
Today I decided to do some preventive maintenance on the Jeep. Found the Oil pan bolts to be loose, so I tighten those back up to 85in/pds. Then trying to figure out the over flow of diff fluid coming out of the breather tube. Plan on calling ARB or hoping someone on this forum knows if it's ok to have fluid come out of the diff like it's been doing. Made a posting under the JK Jeep wrangler.
