Jeep won’t start
×Thank you for visiting Wayalife. It would appear that you have an ad blocker installed and we would be grateful if you would please consider disabling it as ads are how we are able to make this site available to you for free.
Jesus!!! I just disconnected the kill switch and wired it to the battery…. No sparks. Winch works.
I knew these kill switches would add issues… did it start?
I just took a brand new grand Cherokee to the dealership recently for a battery issue. It was leaky battery. What year is it and is it under warranty?
I put a new battery to test it and see if I needed a new aux battery too. Now the jeep is completely dead. Not even a door light will turn on. Nothing. I checked all the fuses. I don’t know what to do. I’m beyond frustrated.
did you replace the auxilary?
I've discovered it controls the door locks, lights, starter; found this out when I removed the primary, got late and was able to lock it up with just the auxiliary, no start but it locked.
I'm thinking the winch switch was bad or wired wrong? was it ever hot to the touch?
I realized today I screwed up the wiring on the winch. All my fault for not reading instructions on the kill switch.
I got the jeep started. Hi pulled out the mega block fuses and #3 is bad. #4 is a spare. I wired it and she fired up. Jeep life ain’t for sissies, that’s for sure. lol.
good you were able to figure it out, blood pressure back to normal?
It’s better… but I wouldn’t say back to normal just yet.
if it was me, I'd replace the IBS (intelligent battery sensor) on the negative post,look for signs where cables may have melted and are causing a short. I'd probably replace both batteries to be safe, definitely check the cables on the auxiliary battery.
What do you mean by the mega block fuse?
the metal fuses with the nut on the head on fusebox. Anyway.... I got everything to work. It was all 10000% user issue. I should have read the instructions on wiring the kill switch on the winch. I basically fried my battery. Oh well..... lesson learned. All good now.
Apparently "kill switch" is an appropriate description. It killed your battery.
good dar, i have Jeep wrangler JL and turn off all energy systems and alerts in screen. When check battery and fuse case, found problems shut off energy. The battery is ok. Cleaner and adjust nut terminals until recover energy. Checking fuses all ok. Finally is recovered energy all system Ok. The Jeep start newlly all ok. After Just 24 hours. 🙁 repeat all sígnals alert in screen until shut off. I check alternator and is ok normal 13,7 volts when Jeep start. Battery is lo e normal 12,3 volts. What japonés?
