Hinrichs build
$150 bucks isnt bad, you could try the rockridge ones and see if you like them. you could always switch to evo skins down the road. i know guys have put your tire carrier on evo skins, but i'm not sure whats involved. jeep is looking good!:thumb:
Just some tabs welded on which is the thing that stops me from getting the evo skins yet since I would have to do it right away, and I feel like Id rather switch over to the Evo carrier as well If I am going to do the skins.
Will post as soon as system lets me!!
I like those, but they always seemed dim to me for some reason.
I was thinking that light kit for now untill I can save up for skins/carrier since I am not sure how bad I really want/need the skins at this time. Just not really a fan of the stock rear tails anymore.
They are not dim. Its a bad pic. Anyway, Quadratec has lots of cool led replacements. Even pep boys has a set for 60-70 bucks that are LEDs! Either way u can't go wrong!
The one thing about about living is pa is that your reverse lights have to turn on automatically when you put your jeep In reverse. That's the one thing that I don't like about the corners
Its not hard to splice into the wiring with some LED's mounted to the rear somewhere.
This might help. Gonna try it on mine, but to an sPod. <img src="http://wayalife.com/attachment.php?attachmentid=63528"/>
So that would make them turn on when in reverse but also be able to switch them on when needed correct ?
ORO's have the reverse light built in! :thumb:
Well just placed my order for a set of the led round tail conversion plates, but from a different person who I think was the first to make them actually. Plus the lights are red instead of white like that one companies (i know i could have swapped them out but still). They do have the small reverse light thats the same as my rock lights which I dont like the look as much, but makes my life easier in the end till I get skins.
Who did you order them from?
brut4ce.com
I was going to order them a while back, and basically forgot about it untill I did a search again. He is painting them today (color matched) which will be nice and make my install easier.
brut4ce.com
Looking forward to seeing them.
