Tackerdown
Banned
^^^^ that's great.
Sent from my SPH-L720 using WAYALIFE mobile app
Well swapping the fronts currently, and they hit the frame at full droop. Hopefully it'll be okay f I don't flex too hard
Shock body, which I think is actually only the one side.
Was going to try and get the rear rockstars installed finally, but can't find anything to lay on to not get soaked.
That reminds me I just need to buy a new one, older one is under an engine block currently
Frost inside my top today, hopefully water isnt starting to seep into it or something weird like that, yesterday it did haver darker "wet spots" on it
What is that white stuff on your boot? :cheesy: Your new avitar looks like you’ve cleaned up a bit since I last saw you! :bleh:
where exactly is it "leaking" in at? you have a pic?
Check the door surround. That piece of material comes off and it leaks in toward the front.
I thought the rockhard was a bolt in.
Sent from my phone?
He means with the welds on the cage itself. Others have had quality control issues.
Cage showed up today, hopefully no weld issues.
