Weebz
Where have you been? Hope all is well. You’re up on 40s now too?
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Don't ask Bill. It is pretty though. I'll let Craig showcase the build though.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Hey buddy im good, just languishing in quarantine. Hope you're doing well. Yea im in the 40s club, with some other goodies:rock:
After installing and driving the Accutune setup with the Fox 2.5 DSC, I can say for certain that is the best setup I’ve driven on a JK. That’s my opinion though. 2.0 coilovers are fine but if your Jeep is heavy then you’re most likely going to end up changing most of the springs out on a bolt on kit. I think on the last JKU we had on the shop with an EVO kit we ended up changing 6 out 8 springs to get the ride height and preload where it needed to be. Does that mean the EVO bolt on kit is bad? No. For most people it’s going to be just fine, but you need to look at your Jeep and it’s weight carefully before you pull the trigger on a bolt on kit and that’s exactly what you’re doing now.
Thanks Bubba. What about doing an Accutune kit with the Fox set-up that is tuned with springs around a 2.0 CO? This would obviously be a full weld-in kit but using the 2.0.
This is consistent with what I’ve heard from a few friends with the bolt on evo set up. A fair amount of tinkering and coil swapping was required to get it set up. For some that could be a negative, for others a plus.
For most JK owners it’s fine out of the box, but as the Jeep gets heavier (and it doesn’t take much) then the tune that’s on them goes out the window. Anything more than 1” of preload and I feel like you really should start looking at spring rate changes.
Just simply looking at pictures of the Accutune and Synergy brackets they look very similar in design and install, but are they?
Well, first off, I hope you’re ok. Did you get it flying? Are you doing better?
Secondly, unbelievable! You’ve been busy! Now I see where Jeff’s been getting all of his dreams from! Is that a Genright kit or full custom? Absolutely insane! Fury’s living up to its name for sure!
2015 JKUR AEV JK350
1985 CJ8 Scrambler
LOL. Sadly not where my ideas came from but he absolutely executed on them!!!
I belive the rear evo kit has additional rear brackets that tie into the frame and coil bucket for extra strength.Is that a kit or a full custom 4 link? Gas tank relocated?
The Accutune set up looks nice. Those weld in brackets take care of my issue with bolt in coil overs using the stock shock brackets which are weak and never designed to hold the weight of the JK.
Sent from my SM-G986U using WAYALIFE mobile app
2015 JKUR AEV JK350
1985 CJ8 Scrambler
