It's been pretty quiet here. Dynatrac informed us the axles are a couple weeks behind schedule, so I'm going to try getting a head start on anything I can do without the axles. I plan on ordering an ARB dual compressor, upgraded stainless braided locker air lines and a PSC cylinder assist. In speaking with PCS, they recommended a Big Bore XDII, pump and reservoir all set up with -AN fittings. -6AN on the pressure side and -8AN return lines and a 8"x1.75 cylinder. This is the first cylinder assist I have run, so any thoughts on that configuration is welcome.
The anticipation must be killing you. Can't imagine having some Dynatracs on order. You already have OBA or is your dual compressor working as OBA and for lockers?
I don't know about all those fittings and stuff for the PSC, but if you just tell what you have, I'm sure they will hook you up. I ordered a complete PSC kit (pump/box/res/ram/lines/fittings/mounting tabs/hardware/clamp) and it had everything I needed to complete the install, the only issue I ran into was that I didn't specify the size of tie rod I had so I ordered one before I started the install. I know for my PR 60 I had to upgrade to the 8" ram.
if you stay busy working on the jeep, the axles will arrive in no time but it will still seem like forever
Hey Benito, thanks for the advice. Your project is coming along really nicely as well. I'm guessing you either split time in New Mexico and Texas or live out by El Paso. Do you ever go out to Las Cruces? It looks legit from what I can tell.
You don't happen to have the part number for that switch Daystar switch pod? I have been searching, but can't seem to find the same one.
could always go with the kit from this guy makes great stuff!You don't happen to have the part number for that switch Daystar switch pod? I have been searching, but can't seem to find the same one.
beautiful.
what did you ever decide on tire carriers? still running the evo hinge?
I'm still undecided. I pulled the rear seat for now, so I have enough room to put the spare in the cab until I figure out a long term solution.
Did you ever installed yours?
