I've seen a lot of Currie breaks. Ring gears, axle shafts, housing itself. Also there is no way to drain the fluid in those axles. That alone is enough to push me away.
enough said, thanks for the input. I will stick with Dynatrac
Yea i feel ya. Personally have no experience with either, but as Overlander said, i have heard of some breaks on Currie. I have never to my knowledge heard if a Dynatrac break. The way i see it, when your spending thousands on something, might as well get the best part you can.The funny thing MedixJK I'm new to this site and was trying to see where I could search for any past threads regarding Currie but I figured it would be faster to just ask the question.
The PR44 doesn't have a drain plug either, at least I haven't found it mine, just so you know.
Right but if you take the cover off it all drains out. That doesn't happen with their rock jocks.
What? Really? How do you drain the fluid/fix ring and pi ions in rock jocks then?
I'm wondering where all these Currie breaks happen. Every rig at KOH seem to use them so if they were bad, those guys wouldn't run them. The only time I see Dynatracs are when the people are decked out in EVO.
Yes I've seen them break but for the amount of them out there, it's impossible for some not to break. I have had zero problems for 2 years and run them hard. Then again, I've had Metal Cloak (which get a hard time here) arms for that amount of time and zero problems.
It's a toss up. You ask here, the love will be for Dynatrac and Evo. You ask other forums it will be Currie and Genright, etc...
Someone at KOH this year snapped their Currie RockJock 60 or 70 housing, like the pumpkin itself split into two. I had a pic of it, but can't find it now. Not the first time it's happened, and won't be the last.
I've been pretty impressed with my core 44 so far. Hit a car in the side at 40mph, bent the car in half. Got a scratch on the housing, lol. Still running it
