Yea I ordered one from oreilly’s if that one ain’t right I’m going to have to make itThat sucks about the intake gasket.
If you could source a sheet of the base material it would be easy to make one that fits.
If you've got an X-acto knife with a good blade it won't be bad at all.Yea I ordered one from oreilly’s if that one ain’t right I’m going to have to make it
Gasket hammer way easier.If you've got an X-acto knife with a good blade it won't be bad at all.
 Now need to order a water pump, clutch and a lot of vacuum hose
 (does it matter?)
 (does it matter?)No updates on the CJ besides finding out I have the wrong seat brackets and have no idea where the originals are
Does anyone have the part numbers for the factory rubicon fox shocks for gladiator? My stock ones are done after the new year run and found some on offer up but person selling them can’t confirm if they are JL or JT(does it matter?)
Thank you for those part numbers! Yea I kinda figured they were tuned different. Looks like those shocks are correct next up is trying to find a rubicon sway barStock Fox JT Fronts:
68341383AF
Stock Fox JT Rears:
68341415AF
The front end of JT/JL is the same, but I think you’ll need the JT bushings for the rear shocks at the frame mount if you end up finding a set of JL stocks.
I don’t know if they’re tuned differently for weight and whatnot however.
I hope that's coming with a lift? lol
Unfortunately not yet lolI hope that's coming with a lift? lol
Yea I saw, if I’m reading it right the vehicle has to be insured as a collector vehicle?I don’t know if your following but Jay Leno is working on passing a smog law for anything older than 1990 to be exempt
Yeah, but it’s stupid cheap. All my vintage Jeeps are under $200 for the year with hagerty. I only drive them on for “shows”. Just send itYea I saw, if I’m reading it right the vehicle has to be insured as a collector vehicle?
Oh that’s not bad at all!Yeah, but it’s stupid cheap. All my vintage Jeeps are under $200 for the year with hagerty. I only drive them on for “shows”. Just send it
