BananaPudding
For those with the 392s, how has your experience been in regards to reliability? I am considering moving out of the 3.6 after several issues (electrical etc..).
Well now, that is interesting!! As you may or may not know, I am having all kinds of electrical problems on my 2020 Gladiator and it's kicking my butt!!Basically the HQ techs shared: that the electrical/computer issues on JLs have gotten increasingly worse with the newer models post 2020. The software code upgrades aren’t meshing with hardware in some cases. The unconnect and the SGW modules. He did say that the least problems they’ve seen electrically is on the 392.
So another anecdotal data point consistent with what Eddie said.
I don’t have a 392, but recently experienced electrical issues on my 2020 JL 3.6.
Took the dealer 1 month to find. They brought in advanced techs from HQ that get involved when local tech can’t figure it out.
I got an opportunity to spend some 1 on 1 time with those techs and asked what’s their experience with electrical issues on the JL since I never had any issues on mine or my son’s JK after several mods.
There really is just so much plumbing on these things now that it doesn't take much to stop up the drain. It is nice that the 392 has a bit less of it.Great points!
Which reminds me that there are no Start/Stop mechanism shenanigans or issues with the Mini-Me battery and the ‘battery isolater’ electronics.
That’s a bummer, sorry to hear about all of the issues you’re having with it.I have a ‘22 392 with the XR package…it is still completely stock. Within first 3000 miles, developed an oil leak; leak source was misdiagnosed by the dealer I purchased it from. It was correctly resolved by dealer in Nevada as an oil filter mount gasket after several more visits to the dealer…took a month to completely wipe all the oil from the undercoat.
Currently sitting at the dealer for multiple dash warnings. A couple months ago took it in for battery voltage warning…sat at the dealer overnight, they could not diagnose the source. Since then, had several dozen battery voltage warnings, then it began to show hot steering oil warnings, which made steering difficult…hence why it is at the dealer for several days now.
I was considering buying another used 392 for my last offroad project…I have since decided against it.
Wow - that sucks.I have a ‘22 392 with the XR package…it is still completely stock. Within first 3000 miles, developed an oil leak; leak source was misdiagnosed by the dealer I purchased it from. It was correctly resolved by dealer in Nevada as an oil filter mount gasket after several more visits to the dealer…took a month to completely wipe all the oil from the undercoat.
Appreciate you posting all this up as I'm still in the process of chasing down the electrical gremlins in my big Gladiator.I’m sure many have read about different causes to the electrical gremlins, but I can share the different test steps the the tech tested in my case
1)aux battery
2)loose connections from aux battery to PDC
3)CAN BUS connectors. Apparently sits close to cabin heater so will bend the pins causing intermittent shorts
4) SGW module
5) Uconnent/radio
6) connection shorts inside the front wheel wells
7) how long after shut off Jeep goes fully to sleep. Apparently it’s a wide range Jeep to Jeep. 15 mins up to 60 mins with no reason
After all that, it was 2 bent pins in my original SGW module. I probably caused it when I disconnected and reconnected the cable to it that was being used with my miniTazer.
Fortunately they found my problem after trying all the other steps, though the elongated processes was an interesting journey into the unknown.
They did share that there have been jeeps they can never solve, So they negotiate some type of vehicle swap with the owner and keep the”electrical lemon vehicle” at certain dealers to scavenge parts.
thank you for this...I sent it to my tech who is working on my 392I’m sure many have read about different causes to the electrical gremlins, but I can share the different test steps the the tech tested in my case
1)aux battery
4) SGW module
5) Uconnent/radio
I am actually bouncing that idea around. Maybe not a TJ but potentially a JK.Buying a 392 is similar to flushing a whole lot of money down the drain. The electrical horror stories associated with the JL in general make buying a JL seem risky. If even a dealership can not figure things out, how can issues be solved if they happen on the trail?
Buying an old low-tech Jeep like a TJ and rebuilding it to personal preferences seems somehow safer than depending on such overly-complex technology.
says the guy with a JL.Buying an old low-tech Jeep like a TJ and rebuilding it to personal preferences seems somehow safer than depending on such overly-complex technology.
