Actually, that floor board doesn't look nearly as bad as I've seen them. I bet a lot of the metal is still pretty solid. You could easily cut out the parts that have rusted through and the surrounding areas and then just patch it with new steel. You can then treat the rest of the floor pan with some POR15.
So badass watching you go through this thing. What a cool Jeep. Ms Cleo predicts a plasma cutter in your future.
Engine oil and trans fluid are brand new so I won’t empty that til I pull the motor.
Gonna start pulling the axles tomorrow I think.
What’s the tube from the bottom of the carb intake back to the block for?
Damn, going balls deep right away? What are your plans for the motor?
Post some pics. It sounds like it could be a vacuum line or could be heated air to help atomize the fuel on colder mornings.
That could be it. It’s just like a dryer hose. I’ve never had a carb motor before so trying to figure it all out.
Okay, is it kind of a big accordian like hose? Like maybe 2" in diameter? If so, it's for emissions and should connect to the bottom of your air cleaner. It provides heat to a valve that opens up when your at operating temps. Of course, you really don't need to worry about this shit being that you have a 75.
That smaller shiny one? It's a heated air inlet. If you can get by without it, great. But it will help with cold starts before the choke fully opens.
Yeah that’s the one. Where would it pull heated air from if everything is cold? Or am I retarded.
As long as the vehicle starts, the air heats up quickly and pumps through that hose into the air cleaner. Inside that air cleaner is a metal door that opens allowing the hot air in. Once the engine reaches a good temp, the door closes and no longer needs the hot air and rather just sucks ambient air from outside through that snorkel opening. I'll try to find a diagram. Just like a lawnmower runs like shit when it's cold out, this feature helps the engine run well faster and sooner. Hot air atomizes fuel way faster than cold air.
You missed the 2nd question....
You’ve never had a carbureted motor before? Damn, carbs are that old already
