I thought all cowls were created exactly equal... ?Contrary to popular belief, all cowls are not created equal.
Nope, Mojave and 392 are more equal than the others.I thought all cowls were created exactly equal... ?
The cowl on a 392 is the same cowl as a sport. No difference in design. The only cowl that is different is the driver side of a 4xe because of the plug in.Nope, Mojave and 392 are more equal than the others.
Well they may work on yours but there are a bazillion threads across multiple forums stating different. The 392 and the Mojave hoods sit higher therefore have taller cowls. I wanted to get the 4Xe cowl to modify for compressor plumbing. No can do.The cowl on a 392 is the same cowl as a sport. No difference in design. The only cowl that is different is the driver side of a 4xe because of the plug in.
Bazillion huh?Well they may work on yours but there are a bazillion threads across multiple forums stating different. The 392 and the Mojave hoods sit higher therefore have taller cowls. I wanted to get the 4Xe cowl to modify for compressor plumbing. No can do.
If I’m not mistaken the hinges are even different on those two models from all the rest.
More than quite a fewBazillion huh?
in my experience of adding lights and stupid shit onto people JL's and gladiators i can tell you they are all the same outside of the 4xe cowl. even installed a roof rack system on a 392 just the other week from metal cloak. they only list tthat it will not fit a 4xe.Well they may work on yours but there are a bazillion threads across multiple forums stating different. The 392 and the Mojave hoods sit higher therefore have taller cowls. I wanted to get the 4Xe cowl to modify for compressor plumbing. No can do.
Nothing to do with the scoop, the cowls are taller and the light mounts and hardware don’t fit, unless you specifically order from the few manufacturers who accommodate the two hoods. There are some out there.Looking at that pic, how would lights mounted be affected by a hood scoop?
I think dem bazillion other guys be wrong
Nothing to do with the scoop, the cowls are taller and the light mounts and hardware don’t fit, unless you specifically order from the few manufacturers who accommodate the two hoods. There are some out there.![]()
He might need a giga-bazillion experienced people to tell him otherwise.I'm confused - multiple people with install experience here say they are the same.
The cowl and hood are the same except for the scoop - they would have to change the windshield frames too and those are all the same
Not really sure why someone would put a t-bone on their cowl but you do you.I’ve been told you can get a good look at a t-bone by sticking your head up a butchers ass but wouldn’t you rather take his word for it?
