Sorry to hear the cat didn’t fix the issue... I was almost certain that would fix it by the sound of what you were saying.
Me too.
Is it possible the coolant is flowing too fast? Are you using an OEM pressure/temp thermostat?
Just tossing it out there. Might be a long shot. With one of my old cars I had unrestricted (no thermostats) and it would over heat because the coolant wasn’t in the radiator long enough. I restricted it and it cooled right down. Especially at idle with only the fan pulling air.
Also. Where is the oil and trans cooler located, in the tanks of the rad? Are the lines free of kinks and build up?
Hmm...Are you sure it’s no sucking air from the heater core leak? Fuck man. Feel for you. I hate these type of issues.
I've considered the flow being too fast, but it never acted up at idle prior to last year. I've put two tstats in from the parts store but may consider OEM. But again, one of these tstats was in there for a couple of years and worked fine prior. Still acts up with the heater core bypassed so I've definitely ruled that out.
Have you tried a lower temp thermostat?
I've done that in the past on other vehicles and it really doesn't do much good on newer vehicles. All of the sensors are based on 195f ECT temp, so by lowering it, it can cause driveability issues. Also, what's going on with mine, it appears the engine is getting too hot, so even with a lower temp tstats, that may delay the issue, but at some point, the cooling system still won't be able to remove the heat.
