WINDROCK End of Summer Pre-Run #3 - May 13-15
The wire is an upgrade. When they first came out, they came with zip ties. I used 4 zipties together and still broken them. I ultimately used a screwdriver and pryed on it carefully. The wire trick has worked for a couple people I know for sure. Good luck.
FYI, if you do damage the rope at that location, that's not where the force is held. The winching force is held with the first 5 wraps on the drum, so you'll be ok. I'm not telling you to be careless, but if you do knick the rope there, you won't be out of luck, it will still winch fine.
Thanks for the info, Almost felt I was doing something wrong because it was so hard to pull into it. If the rain brakes for a while I'll try again
Headed out now, but this traffic though...
I can't believe I'm the only one that caught this! Why are your stock wheels and tires inside the jeep!?
Just left Windrock and it was pouring down, will truly be sloppy on the morrow. ;-)
Good to know. Need to bring the big boots.
What is everyone doing Sunday?
My plan will be to pack up and head to "mother fucken waffle house". (In the words of the great Frogmech)
I agree with ya. I used a 12 gauge wire and a small touch of wd40 to get mine through. Not a bad design but sometimes can be frustrating.
Looks like the weather might be clear tomorrow! After the torrential rain today it will probably be messy on the trails! Ought to be fun!
Haha yup i have officially joined the open diff and d30 gang. Got a feeling Josh and i will being battling it out with our open diff stick 2dr's on 37's.
And then there's me the open diff stick 2door on 35s this should be interesting. Lol
