whytiptoe
The wire is an upgrade. When they first came out, they came with zip ties. I used 4 zipties together and still broken them. I ultimately used a screwdriver and pryed on it carefully. The wire trick has worked for a couple people I know for sure. Good luck.
FYI, if you do damage the rope at that location, that's not where the force is held. The winching force is held with the first 5 wraps on the drum, so you'll be ok. I'm not telling you to be careless, but if you do knick the rope there, you won't be out of luck, it will still winch fine.
Thanks for the info, Almost felt I was doing something wrong because it was so hard to pull into it. If the rain brakes for a while I'll try again
